Powerflex front lower control arm bushes
Steve84N
I'm selling my Powerflex front lower control arm bushes, sometimes called the lollipop bushes. These are the ones that always wear out causing poor geometry and therefore steering response.
I'm selling as I've now switched to a stiffer offset bush but this has only done around 10,000 miles. I immediately noticed better steering feel when I fitted these. The hardest part was without a doubt removing the old standard bushes so you get to buy them ready fitted to the aluminium outer. This turns it from a garage job to one you can do on the drive. All the Powerflex grease is still within the bush so you just need some washing up liquid to help slip them on the arms.
£55 posted.
