Got a problem with my trunk tray switch. About half the time I have to go into the trunk and jiggle the tray a few times to loosen up the switch.
(yes...the tray is all the way down...always has been down) :roll:
You can hear the switch click on/off as you raise/lower the tray, and there seems to be plenty of travel in it, not like it's set right on the verge of clicking on or off. Sometimes, even after I know it's switched on/off several times, the top still won't go down until I jiggle it a few more times. It's like there is something loose inside the switch, or maybe corroded inside the switch mechanism. I don't know how the switch gets set (and stuck) in the "interrupt" mode, once it's already set in the "go" mode, but it does every few days. Sometimes more frequently. :x
I had it replaced once by the stealer when it was under warranty. Has anyone replaced one of these tray switches? If so, how hard is it to replace?
Thanks!
(yes...the tray is all the way down...always has been down) :roll: You can hear the switch click on/off as you raise/lower the tray, and there seems to be plenty of travel in it, not like it's set right on the verge of clicking on or off. Sometimes, even after I know it's switched on/off several times, the top still won't go down until I jiggle it a few more times. It's like there is something loose inside the switch, or maybe corroded inside the switch mechanism. I don't know how the switch gets set (and stuck) in the "interrupt" mode, once it's already set in the "go" mode, but it does every few days. Sometimes more frequently. :x
Thanks!
