For some months lights would come on the dash and scanner indicated heater elements on bank 2 sensor. Reset the code and lights would stay off for a few weeks. My car is the 2005, 2.5SE.
Decided to replace both sensors but they seem to be in short supply, Bosch that is. You can get other makes or those generic ones where you cut the cable and reconnect at the top end of the engine but stayed clear of these. In the end, managed to get them from AutoDoc but they took a few weeks to arrive.
Jacked the car up but simply didnt have enough space to get under there and access the sensors so booked the car into my friendly local garage.
They did the job but said it was a nightmare getting the old ones out. They eventually had to resort to unorthodox methods but stripped the threads of the old sensors and retaped the thread in the exhaust. They thought that originally special grease had not been applied to the thread and basically the sensors over time welded themselves into the exhaust.
They charged £216 for fitting them which I thought was not bad for nearly 3 hours of work. I spoke to the mechanic who did the job and he said
it was an entertaining job which came close to destroying the downpipe but he was happy I wouldnt have a problem.
So beware if this is a job you are contemplating yourself.
