Possible group buy: alu-look radiator covers
From OEM fits these.....
Part Number 51710309268
Alu-look radiator cover
Part 51710309268 was found on the following E85 vehicles:
Z4 E85, Z4 2.2i, Roadster, M54, EUR, (BT11) : Alu-look radiator cover
Z4 E85, Z4 2.2i, Roadster, M54, EUR, (BT12) : Alu-look radiator cover
Z4 E85, Z4 2.5i, Roadster, M54, EUR, (BT31) : Alu-look radiator cover
Z4 E85, Z4 2.5i, Roadster, M54, EUR, (BT32) : Alu-look radiator cover
Z4 E85, Z4 2.5i, Roadster, M54, USA, (BT33) : Alu-look radiator cover
Z4 E85, Z4 3.0i, Roadster, M54, EUR, (BT51) : Alu-look radiator cover
Z4 E85, Z4 3.0i, Roadster, M54, EUR, (BT52) : Alu-look radiator cover
Z4 E85, Z4 3.0i, Roadster, M54, USA, (BT53) : Alu-look radiator cover
Looks slightly different in the OEM picture..........
http://www.realoem.com/bmw/enUS/showparts?id=BT11-EUR-12_2002_E85_BMW_Z4_22i&diagId=03_1585#51710309268
Not sure if the one shown on the BIMMERFORUMS pic would fit.
Cheers Alan, the one in the Bimmerforums has been modified to fit the Z4M. The pic on realoem in the diagram is how it will arrive. Both are the same part.
AlanJ said:
If it's as the OEM pic then sign me up - thanks :)
Will do. It will be as they are genuine OEM parts so should be as per realoem. Will double check on Monday for piece of mind. Little basic cutting required for our M friends by the looks of it.
Mr Aero said:
Hi, could you please count me in too. Price dependant.
Is the piece made of aluminium or plastic?
Cheers.
it states alu-look so it's plastic you would think from that description.
tbh i don't see the need to spend £40 on making something hidden away look any better. i'd rather spend the £40 on external cosmetic upgrades you can see on a daily basis. good for those that have a modded zed and go to shows and stuff though.
maxman said:
Did you get in touch with the company to find out a price?
Tried emailing from different accounts in case it was going to their spam folder, and also left a voice message and didn't get a reply to anything unfortunately.
