Porsche calipers and CSL discs
Tanel
 Tallinn, EST
Is it possible and what is needed to fit Porsche Boxster S calipers with E46 M3 CSL discs to a non M Z4?
I found some info about fitting those to an M but I'm not sure about fitting those parts to a non M car.
I've done this on my Z4M although before I had the M I originally looked at doing it on my 3.0si.
It should be bolt on using these brackets with CSL discs:
https://www.ebay.co.uk/itm/254056894907
I did this last year Porsche calipers, 345mm csl discs, creation motorsports brackets and Pagid RS29 pads - AWESOME
Hi Kev,
do they fit the 224M standard Z4M wheels?
Thanks in advance
Attilio
Hi Greg,
standard 224M wheels ok for that set up?
Attilio
Fronts will need a 10-15mm spacer or they'll start milling a nice groove in your wheels.
Rears, if you decide to do the whole kit as I did, will require you to remove about 30% of the backing plate so that the caliper can fit :thumbsdown:
Whats a set of the Porsche calipers worth?
Will depend on condition, but I paid £1000 for a 4 wheel set...although they did need a new bleed nipple and hose as one of each was seeping.
Finish would need a media blast & repaint if they were meant to be a permanent fit, but they were meant as a stopgap whilst I got some brackets made to fit some GT3 Alcons (other thing have delayed them though).
Jeepers thats bit spendy - can you remove the logo? Gives a whole new meaning to hybrid car. :?
Cant run anything less than an 18" wheel , I run 18 x 8.5 et37 all round
I picked up calipers for £300 (fronts only) keep an eye on fleabay, not to bothered how they look as long as they perform :D
