Polishing your hazy headlights
gapTech
 Stafford
Hi folks.
My headlights have gone a bit hazy, has anyone successfully polished their headlights?
There's lots of videos on you tube of people using toothpaste, does this actually work?
Thanks.
gapTech said:
Hi folks.
Thanks.
"ben g " recently did his & so did my son on his Mk5 Golf , relatively cheap & easy with great results :thumbsup:http://www.amazon.co.uk/Meguiars-G1900UK-Headlight-Restoration-Kit/dp/B001O7I7FS/ref=sr_1_sc_1?ie=UTF8&qid=1414705227&sr=8-1-spell&keywords=meglars+headlight+kit
i also used the meguiars kit recently and was very impressed with the results. it gets a big thumbs up from me. :thumbsup:
Did mine with the turtle wax kit - worked perfectly.
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=66238
Done mine with Rain X plastic cleaner and then polish. Best done with a power tool, but take care not to allow heat build up or you risk melting and smearing the lens.
In theory toothpaste would work as it's only a mild abrasive, but why not just use the correct stuff..
Make sure you seal them afterwards with a hard wearing wax, otherwise they'll tarnish quickly. Toothpaste and Meguiars are ok, but wet and dry, followed by a medium then soft compound polish, is the only long term method of removing scratches, chips and the hazy look.
http://www.amazon.co.uk/3M-Headlight-Restoration-Discoloured-Headlights/dp/B0078IHJ1K/ref=sr_1_1?ie=UTF8&qid=1415114007&sr=8-1&keywords=3m+headlight+restoration+kit
Best one by far.
What grit are you suggesting? 2000, 1500?
I uses some fine wet and dry then just polished the plastic with poor boys cutting compound and then polish until clear.
Best one by far.
That's the one I used. Fantastic and easy to use.
ben g said:
Best one by far.
What sealer did you use afterwards as I still need to do this?
I bought some from amazon that was recommended in a review of the 3m kit. Seems to do the job well enough.
http://www.amazon.co.uk/gp/aw/d/B00A3S1RGU/ref=mp_s_a_1_5?qid=1415202999&sr=8-5&pi=AC_SX110_SY165
I'm plus 1 for the 3m kit. Worked brilliantly. Why bother trying to work out what grit number you need to use. Its all in the kit. Worry free results.
