jamie_z4 said:That sounds like the usual dmf rattling it's tits off
Dual mass flywheel that is part of the clutch set up .Marlon said:Mine does that too - on idle, then goes quiet when clutch depressed. What's a dmf ?
mr wilks said:Dual mass flywheel that is part of the clutch set up .Marlon said:Mine does that too - on idle, then goes quiet when clutch depressed. What's a dmf ?
I did have a Z with the above noise , my indy talked me out of replacing clutch + DMF saying it was most likely that way for the last 30k miles & will most likely be the same after another 30k , , performance was not affected to the best of my knowledge
