Planet Sun Star Comparison
peddy
Veteran
 London
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Q5M3t0SOZSM&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Q5M3t0SOZSM&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
I seem to recall from somewhere that the sun is 110 time bigger than the earth... :o
That's a bit confusing. Its diameter is ~100 times bigger, but if you're talking volume/mass, then it's bigger on a whole different level.
Sun/Earth Comparison
Bulk parameters
Sun Earth Ratio (Sun/Earth)
Mass (1024 kg) 1,989,100. 5.9736 333,000.
GM (x 106 km3/s2) 132,712. 0.3986 333,000.
Volume (1012 km3) 1,412,000. 1.083 1,304,000.
Volumetric mean radius (km) 696,000. 6371. 109.2
Mean density (kg/m3) 1408. 5515. 0.255
Surface gravity (eq.) (m/s2) 274.0 9.78 28.0
Escape velocity (km/s) 617.6 11.19 55.2
Ellipticity 0.00005 0.0034 0.015
Moment of inertia (I/MR2) 0.059 0.3308 0.178
Visual magnitude V(1,0) -26.74 -3.86 -
Absolute magnitude +4.83
Luminosity (1024 J/s) 384.6
Mass conversion rate (106 kg/s) 4300.
Mean energy production (10-3 J/kg) 0.1937
Surface emission (106 J/m2s) 63.29
Spectral type G2 V
Model values at center of Sun:
Central pressure: 2.477 x 1011 bar
Central temperature: 1.571 x 107 K
Central density: 1.622 x 105 kg/m3
Yep - it's 'bigger' by most measures, but sure don't see much of it this side of the planet in December :thumbsdown:
as for OP post - fascintating until the last few seconds when the presenter went off on some tangent.
