Pin out on stereo connectors
SideExit
Hi guys, I have done a search but can't find what I'm looking for.
When I bought my Z a year ago I discovered some time later that although the 6 disc changer appeared to function correctly, there was no sound.
Now the person who had he car before me was a "fiddler" as I get an annoying chiming when I reverse and the sat nav is updated with speed cameras etc.
I am guessing they had a dice or intravee fitted and didn't put it back together correctly!
Does anyone have a diagram that shows what pin on each connector does? I'll then rip the dash apart and check this before doing anything else.
Not sure if it matters but I have sat nav (obviously from my previous comment) and DSP.
Hope someone can help!
check that the coax cable is plugged into the back of the cd changer, and also plugged into the DSP amp.
should be a small black cable with a round silver 90-degree angled connector on it.
lift the carpet against the back wall of the boot and there's an access cutout located in the center lower of the bulkhead to access the back of the changer.
