alex85 said:Why would being an 03 be a help?
Do you have a sub behind each seat? If so, take the cover off and tell me what it says on the cone?
sniry said:same here, i have the 3 dsp setting and 2 subs behinde the seats, but i have no amp in that position.. could it be some where else? i remember when i was looking for the BT code on the moudole behinde the seat i notice some thing that look like this ..
by the way its 08 american market Z..
Where is the barcode? I've got the amp but don't remember a barcode.Tommo said:alex85 said:Why would being an 03 be a help?
Becasue I have a Carver amp but wasn't sure if it was the same set up as in the 2006.
Anyway...
If you haven't found it yet heres a pic, The barcode down the side actually says Carver on it if you look carefully.
ay8306 said:I beleive that the DSP is located on the passenger compartment wall behind the seats in the trunk (boot) in post face-lift cars. The picture below is from a Dice Install How-To I posted a while back. I am fairly certain that the box to the right is the DSP - that's what the label said anyway. Like Smokin said, all 2006+ 3.0si are equiped with DSP / Carver.
