srhutch said:See your back to your old tricks![]()
Yeah you are rightSwiftly said:If it ain't broken Andy don't try to fix it :roll:
andysat said:So its not just me then-i tried leaving the petrol filler door open as i locked the car -saw the locking pin come out and sprayed a little wd on it -still the same tho
Ok mate-will domarkeg said:Rather than WD on the pin, squirt some little light oil down the hole when the pin's recessed, and unlock/lock a few times, see if that helps? Also, check your locking pin recess hole in the filler cap, make sure nothing's lodged in there?
cj10jeeper said:andysat said:So its not just me then-i tried leaving the petrol filler door open as i locked the car -saw the locking pin come out and sprayed a little wd on it -still the same tho
Aaarh not WD40. it has thousands of uses but as Markeg says use light oil. WD40 dries over time to a thick solid substance and tend to clog things up.
Thanks -i will check it outmarkeg said:BTW Andy, if the loud noise is the 'thunk' and not the motor, then it may be that your filler cap door has moved slightly rather than the pin moving too far and hitting the end of the recess. Try to see if the noise is coming from the recess end rather than the motor end, and check the gap around the filler door when its closed, should be constant all the way round.
Stuart Truman said:It's the newer thicker armour plated pins. These are needed to protect the expensive stuff from the scrotes
