Good point, i will take a look.. any ideas where the beeper is??enuff_zed said:Possibly just the 'beeper' then?
ie, they're working fine you just can't hear them.
Is that a separate fuse?
ibasniper said:Good point, i will take a look.. any ideas where the beeper is??enuff_zed said:Possibly just the 'beeper' then?
Thanks...i have some time tomorrow so i will take a look.parabolica said:Speaker is on the lower cowl to the right of the steering wheel - a few screws holding it on, so super simple to remove. Once off/down you’ll see a small speaker with one, possibly two connections on it. One is the PDC, the other is a constant warning that the car is in reverse - chances are that one will be disconnected as it’s annoying as fook when it’s plugged in.
