smorris_12 said:I'd start from the point of thinking about the reverse light switch. Not sure if that runs directly to the rear cluster or the LCM tho.
cheers BenZedebee said:Have you checked where the PDC connects into the main loom, which is behind the carpet on the driver’s side towards the rear of the boot? There’s no slack in the loom and it might have pulled loose, particularly if someone has had the bumper off in the past.
markplant said:Don't they plug in to a module in the boot, if I call on Saturday your welcome to try the one from mine
The module is behind the carpet on the drivers side where the boot lamp isbigwinn said:markplant said:Don't they plug in to a module in the boot, if I call on Saturday your welcome to try the one from mine
Cheers bud!
