passenger window
kayve
New member
hi, my window is loose but still works. can i take the door panel off to try and sort it or is it a dealer job because of the side airbag
Yes you can take it off. The airbag can be unbolted (3 bolts) and suspended so as not to pull on the connector or loom if you need access behind that area.
If you disconnect it with the ignition on it's a trip tot he dealer to have the irbag warning light reset.
