Hi All
Yesterday I stripped the passenger door panel down in a hope to replace the cable (bought replacement kit from ebay), but have hit a bit of a snag. Because my window is not working at all, I can't drop it down to access the TORX bolt so I can remove the window, and then remove the regulator and motor. Any ideas how I proceed?
I had a feel around all the cabling and all feels tight and in good condition so I'm guessing it's the motor that has failed (I'm trying to source a 2nd hand one from ebay but no luck so far). But until I can find away to get the old motor out I'm sort of stuck. FYI the relay clicks when I push the power window button, but no movement/noise from the motor.
A 2nd issue, after putting all back together my airbag light has now appeared, I did follow the procedure of removing negative battery lead and waited 10 mins, but I reinstalled airbag a couple of times while checking connections/relay etc and I think a got a little impatient and maybe only waiting a couple of minutes the 2nd time. So my advice, be patient and wait the full 10 mins for the electricity to bugger off, before disconnecting airbag. I tried to reset this with my CARLY but no luck, I have read that other cheap OBD scanners will do this such as Creator C310, anyone have any experience with this?
Thanks,
Jim
Thanks,
Jim
