Passenger airbag deactivation kit
Z4hid
Harrow, NW London
Hi,
Bit of a long shot but want to retrofit a passenger airbag deactivation kit and wondered if somebody has one that they purchased before they were discontinued by BMW and didn't get around to fitting... as I say a long shot but thought I'd ask.
Zahid
I bought this switch off eBay: https://www.ebay.co.uk/itm/262246647757
My 2003 already has the wiring - so worth checking to see if yours has it or not? (The switch wiring is a 5 or 6 pin plug from memory, but only has 2 pins in use)
They are keyed though - but it took me like 5 mins to unscrew it, pull it apart quick, and remove the lock barrel pin things (They just pull out) so now it will turn with any key / any object
You can buy the light from here also: https://www.ebay.co.uk/itm/263994214571 which I think is the same one. Again, if your car was pre-wired for it, the cable is tucked away under gear surround somewhere
Thanks for that information and detail and glad it worked for you. I will look into it. :thumbsup:
