In my quest to retrofit everything possible into my E85 I installed the passenger airbag bypass switch as I already had the prewiring. This included a new center console with the light located opposite the sport button. Sourced the secondhand bits and modified the barrel so my key works with the switch and all went well, light comes on when the ignition turns on and goes out couple of seconds later to show the airbag is working. However when I turn the key to deactivate the airbag it does not trigger it and put the airbag disable light on. I read on a post somewhere that the key needs to be programmed to the switch but I have no idea how to do that, does anyone have any ideas or is this a stealer only solution?
Possibly could it be similar to programming a new key to the car if so what is the procedure?
