Part number please
BTZ461
 Christchurch New Zealand
Part number please for the rubber flaps in front of the front wheels E86 coupe. Look like they are mounted off the bottom of the inspection panels in the front wheel arches. Thanks in advance.
There are two flaps - one for the headlights and one for the fogs; depending on which you need I have a spare set going that you can have for the cost of postage. I honestly can't remember if it is the upper or lower flaps that I have but will check when I get home at lunchtime.
Thanks parabolica. The items I mean are like a gurney flap for want of a better word, and are located in front of the wheels, and hang down about 20 or 30mm. And it looks like they are mounted on a panel below the lower (foglite) inspection hatch. Easy to clip on a kerb........
Thanks skelters too, am familiar with realoem, but can't see these anywhere.
Ah ok I think you mean the under-tray section? The pieces I have are the plastic flaps that cover the inspection hole for the fog lights.
Found the numbers cover bottom left and right 51717168995 / and 6. Not cheap either seems to be around $250US EACH !
