Parking Sensor Won't Turn On
Thenuclearcat
 London
Hi,
For some reason my parking sensors in my 23i don't seem to be working (all of a sudden too).
By not working, I mean:
In reverse gear, the switch doesn't light up and no beep emits.
If you toggle the switch, no light shows.
I located the fuse for the parking sensor in the fusebox within the glovebox and it was fine, however after swapping it for a brand new fuse the problem persists.
I've had a root around the boot for the PDC module however I'm having difficulty locating it. Worth mentioning I've never had any moisture issues.
Any help would be amazing!
Hi mate,
Put your ear to the sensors to see if there are any clicking noises coming for them when the ignition is on and in reverse, If one isn't clicking then a new sensor it is.
