deka said:Bit new to the idea of getting a DA polisher for the car and taking on detailing....
My question is how many times can you machine polish a car.. i would expect that each time you do it a layer will be removed,,, ??
p28msc said:im watching this thread with real interest, Im teetering on the edge of trying machine polishing but im now having second thoughts as i dont want to get a panel to practice on as if its that dangerous then i probably wont bother which is a shame as i was expecting to really enjoy polishing
Z4-35i said:Don't be afraid of machine polishing, the idea of getting a cheap panel from a breakers for £15-20 is that you can try out different combinations of pads/compounds and also to feel comfortable using your machine to practice polishing out marks and defects. You can rough up the practice panel and polish out the marks, which is not something you'd want to do on your actual car.
You will eventually go through so be carefull.deka said:Hasn't put me off giving it a try i was just asking if i could only do it say two or three times..... need to read up on how to do it or book a course![]()
domsz4 said:this might be a bit of a daft question but do you have to do it everytime with a cutting compound or is it a case of once a year and then just a normal polish after that using the machine...
p28msc said:domsz4 said:this might be a bit of a daft question but do you have to do it everytime with a cutting compound or is it a case of once a year and then just a normal polish after that using the machine...
Thats a good question, im after coating the car in a wax each time rather than paint correction
