veilside85
evening,I'm gonna be upgrading my brakes to pagid rs29's on the front with new discs as well.regarding the rear should i match the rear with the same pads or do the originals do???
TomK said:As long as you don't do it the other way round you'll be fine. Ideally of course you'd do the lot, but in any case it's far better (safer!) to have more brake performance on the front than the rear.
Great brake pads btw, expensive but worth it, last ages, stop superbly.
You don't necessarily need to replace the discs if you are changing the pads, even with the different compound. It would be nice to, but assuming there's life left in them then just crack on and change the pads if they are looking low, otherwise just wait.veilside85 said:just didn't fancy replacing the rear discs as well.
TomK said:You don't necessarily need to replace the discs if you are changing the pads, even with the different compound. It would be nice to, but assuming there's life left in them then just crack on and change the pads if they are looking low, otherwise just wait.veilside85 said:just didn't fancy replacing the rear discs as well.
Purely motorway work you'll probably get 60,000 miles out of a set of discs.veilside85 said:What sort of mileage do discs generally last for the car is on 47k now.they don't look to bad at all
Z43.0Si said:I'm looking for some uprated pads. I saw these and it sparked some interest..... and then I saw the price! I would hope they are amazing for that money.
veilside85 said:evening,I'm gonna be upgrading my brakes to pagid rs29's on the front with new discs as well.regarding the rear should i match the rear with the same pads or do the originals do???
