Hi everyone,
Since Friday I have been the proud owner of a Z4C and haven't stopped smiling since! Actually that's a lie, I stop smiling twice. The first time was when the air con stopped working mid drive and started blowing out warm air, the second was when the temperature gague beeped when it hit red after being stuck in traffic. When the overheat happened it was about 27 degrees celcius outside, again the air con wasn't working, and once I started moving and turned the heaters onto full heat and maximum blow, the engine temperature came down very quickly. Once I stopped again though it would start to creep back up, and I can't recall the auxiliary fan coming on.
Once I got it home and let it cool down, I checked the coolant levels which were full and the oil filler cap was free of oily mayo substance. So definitely no leak of water and the gasket is fine. I then started it up and left it at idle, waited for the engine to come up to temperature with the needle point straight up, after 10 miuntes of idling the temperature stayed perfectly normal without the auxiliary fan coming on, by now the air temperature was much cooler.
My question is, has anyone had any experience of this before? I am leaning towards something intermittently wrong with the operation of the auxiliary fan as I know for the air con to work the fan must be turning, but I have also read that people with overheating problems had the problem fixed by replacing the water pump. With the symptoms given above, does anyone have any suggestions as to what the problem may be?
Any help would be greatly appreciated....
