Yesterday I managed to bump the front of my beloved Zed. A Mondeo had a huge tow bar that was sticking right into the parking space that I pulled into. I didn't see the bloody thing and I hit it. It didn't cause any visible damage, just left a black scuff on my number plate.
I left the supermarket and went back to work. A few hours later after work I jumped in the car to drive home. After about 10 minutes I noticed that fan had kicked in. Another 5 minutes later the temperature gauge was heading for the red zone
And it eventually beeped and lit up red so I pulled over to let it cool down. After about 10 minutes I set off again. I don't have breakdown cover and I was on a tiny lay-by on the M62 in rush hour traffic, I didn't feel safe. 5 minutes later the temp gauge hit red and the car went into limp mode. I drove the last 10 miles home at 30 MPH in rush hour on the M62. I pissed off a lot of motorists!!
Once home, I let the car cool down before checking the coolant level. Almost empty, maybe totally empty! I topped it up with some decent coolant and fired her up for a bit. A friend who is a mechanic told me to run it with the heaters on full and to unscrew the little bleed valve on the pipe near the coolant filler cap. I did this for 10 minutes and the temp gauge stayed dead in the middle. I put the coolant cap back on, tightened the bleed screw and let it run for 5 more minutes. The temp gauge still didn't move from the middle so I went for a drive. 5 minutes later the temp gauge started heading for the red zone so I turned round and got back on the drive before it hit red. I also noticed that the heaters were blowing luke warm even though the car had been running for a good 15 minutes. They are usually blowing red hot after 15 minutes.
I've just checked my coolant level now and it is low, maybe almost empty. There's a damp patch under the car too so there's definitely a leak somewhere. Could a leak cause these symptoms? From what I have read this sounds like a faulty water pump although I'm crossing my fingers that it is something else because I don't fancy shelling out £500 for a new water pump plus fitting.
I'm also wondering if I could have caused any damage by driving it that last 10 miles in limp mode? It seems to start and idle fine. I hope I've not fried the engine.
Is it just a coincidence that I bumped the front end too or could that have knocked something loose? I can't visibly see anything loose nor can I see coolant dripping from anywhere.
