Outside Temperature display
cruisingdog
New member
Hi Guys, I have an 2006 z4 2.5i automatic E85. I recall that the cluster would display the outside temperature but for some reason it doesn’t do this anymore. I have used PA BMW scanner 1.4 and 8 feel like I might have mucked something up in recoding the IKE cluster.
Would appreciate if anyone has any clues how to get outside temp displayed.
On a side note I just installed a M turn signal with the BC button on the end (in the hopes that it would activate the computer stuff) but the car doesn’t recognise it (Not sure if the car has the module needed for this anyway but the turn signal was uber cheap so it was worth the risk). Any thoughts here too.
FYI, I’ve had this car for a long time and I think I lost my old account here, hence this newbie account.
Thanks.
Just figured it out. In the IKE section you uncheck all the on board computer check-boxes. 3 boxes bottom right. If you want the clock on the dash, check any of the boxes and it defaults to only showing Clock. In my case my CD player has a clock button so I can see the time anyway.
