P Paul c Member Jun 6, 2013 #2 Just keep your finger pressed on the door open on key fob windows will drop and roof will open takes a second or two to kick in
C Carol M Lifer Jun 6, 2013 #3 Yes, hold down the door open button. It won't close it unless you ordered comfort access option.
A api330 Member Jun 6, 2013 #4 Thanks for that and yes it opened, How do I attempt to close it to see if I have the feature just hold the lock button ?
R ronk Lifer Durham Jun 6, 2013 #5 No that won't work. Afraid its a sit in the car and press the button.
C Cool Z4 Active member So. Cal, USA Jun 6, 2013 #6 Maybe put key on the door key hole and twist to lock and hold it there. Don't remember cause I don't need to use this option.
R ronk Lifer Durham Jun 6, 2013 #7 That option used to work until they did the security update. I have asked if this could be re instated buta BMW have said no.
