Posted a couple of times about this, but need to sanity check I'm not going mad.
So, left alone, battery is going flat inside 3 days.
Have checked amps on shut down looking for a parasitic drain - shuts down normally, draws just 0.02 amps when fully shut down so appears not to be a problem there.
Followed some advice from here looking at the volts from the alternator when running, sits at 14v, drops briefly to 12v when loading up (lights, full beam, fogs turned on) and then quickly comes back up to 14v so clearly not an alternator issue.
Process of elimination therefore means can only be a defunct battery. It's a Bosch S5, bought a year ago, so it's strange it would be faulty, but I cannot think of anything else that could be causing it to go flat inside 3 days, so it must not be able told a charge.
Any other ideas welcomed, or please tell me I'm not going mad and this is the most likely cause.
Car is expensive driveway porn at the moment as it's unusable
Stu
Stu
