One touch window stopped working
Marlon
 Lancs.
I've had this problem before and fixed it: basically the drivers side window has decided it doesn't want to raise with one touch. I have to keep the switch pulled until it fully closes. I've tried the suggested fix - dropping the window and keeping the switch pressed down for 10 seconds, and also tried closing the window and keeping the switch pulled up for 10 seconds, but it still won't play :headbang:
Mines done the same after disconnecting the battery :(
Mine has done this one the passenger side I had it checked out after trying all the methods under the sun and found it was the regulator in the door mine wouldn't auto up when roof was dropped and closed when button was held in also. £170 from dealer and that's just the part. Will look to possibly get this done but with the airbag module going just before Xmas (£550) I want a couple of months garage free.
