I've tried everything I could find on the forum to remove the whip. Finally resorted to mole grips (with a piece of cut hose pipe to protect the base of the whip) and it looks as though it was unscrewing from the base. Did not have the courage to keep unscrewing as I suspect its the aerial plastic covering that rotating, shards of black plastic were coming from under the bottom of the aerial.
Screwed it back down again and reception is still OK.
I'm thinking the only recourse now is cut away the base of the aerial with Stanley knife, expose the metal part under the plastic and unscrew whatever is left with molegrips. It seems a bit drastic, the arial will be scrapped and, having read earlier the base may start to turn I'm undecided whether to carry on.
I'm OK with whip but bought a stubby (OEM) as I didn't want to cut a hole in the indoor cover I've just bought.
Anyone ever had something like this? could really do with knowing what the aerial base is like under the outer sheathing.
