InterlagosMC
Im wanting to check the oil pressure in my M coupe and can only see the second outlet for the oil filter housing to connect onto from searching online, this means removing the air box which I didn’t really want to do for such a quick check.
Is there another pick up point I can use to check oil pressure?
Wanting to check this as I’ve recently fixed some oil leaks and want to check how healthy the pump is to see if it needs replacing.
