Oil leak with picture.
Andy219
 Gloucestershire/Lincolnshire.
Hey guys,
I have oil building up where the red circle is and running down to where the red arrows are causing little puddles of oil.
The yellow circle indicates a blue adhesive of some sort which makes me think this area has been worked on before I bought the car.
Has anybody come across this before and knows what the problem is?
Would be much appreciated :D
Thanks,
Andy.
Leaking gasket that someone has tried to bodge with silicone or similar on the outside. Needs a new gasket fitting
Not done the job before but will be a simple removal, clean the faces and fit new one.
Damn bodgers!
Thanks for the reply, I'll search the forum for an how to tutorial of some sorts :)
Did a cam cover gasket replacement on mine a while back:
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=90194&hilit=Cover&start=75
Bit of a long-winded thread but maybe a few pointers in there to help you out.
Relativelt straight-forward job. Make sure you check the cover for hairline cracks.
If the gasket is hardened in places then its most likely the gasket but i understand they leak mostly from the bottom at the back wheras urs is at the top at the front!
I followed igeek691's handy youtube vidas below. Good luck and feel free to give us a shout if any info required....
igeak691 wrote:
My How To
https://www.youtube.com/watch?v=IlBby98Kg-w
Remember to make sure the gasket is sealed well, use RTV at the edges.. it's what caused my latest video
https://www.youtube.com/watch?v=rXXzsVah6UM
