Hi fellow Z4 owners!
I've recently purchased my first Z4 last month. It's a 2006 3.0si coupe and am absolutely loving it!
I've probably done about 800 miles so far and the other day noticed the oil light came on after I turned the engine off. Upon inspection of the engine bay I noticed a small pool of oil around the oil filter housing.
There are also signs of it splashing onto the underside of the bonnet.
Browsing the forums it looks like it's a common problem for the rubber seals on the oil filter housing to degrade over time and start to leak. I called my local indy who quoted about an hours labor to replace the seals but mentioned that the likely cause of the leak is down to a blocked oil breather?? He then quoted me £500 to replace the breather and stated that if I didn't then the leak would likely come back within a month or so!
Is this likely the case or can I get away with just replacing the seals? I couldn't find much information on the forum about blocked oil breathers.
The leak is fairly small, I've put in half a litre and the oil gauge is still showing 3/4 bars for the last 150 miles. Mileage is 44,000.
Any input or experiences would be appreciated!
Thanks,
Simon
Thanks,
Simon
