GarethFishr
Hi folks,
Had a couple of fault codes on the Z -
P3242 - relating to the Thermostat
P0102 and P0113 - Air Intake Sensor/MAF
Order both parts which are relatively un-expensive. Whilst taking the splash tray, airbox and fan out I've noticed a few issues.. one of which is the belts are cracked but that's easy enough to order a new set and replace.
Howvever, the oil leak is hard to diagnose due to parts of the car attached. Has anyone else have an oil leak in this place? I suspect its the head gasket but wondered on others experience. Oil is only in front of the left (passenger side) engine mount in the square shown and is collecting a small amount in the little grooves - no oil is on the floor of the garage.
G
G
