I like to do an oil change inbetween long life services. Its really quick and easy using a Vacuum pump to suck all the oil out but this needs a dipstick for the suction tube to enter the engine.
As my facelift doesn't have a dipstick is it possible to go through the filter housing?........highly doubtful but thought i'd ask just in case.
I am assuming I will have to do it the old fashioned way and remove the drain plug which is a pita. I have not been under the zed yet, will it need jacking to get to the plug? If so I would like to put axle stands underneath before crawling around under it (safety first!) Whats the best way of doing this? I have a hydraulic jack, is there a single jacking point at the front so that axle stands can be placed at the sill jacking points?
Advice much appreciated
