OEM mesh windbreak
AGDelaney
I know that this may sound a daft question, but what do you attach the hooks to on the mesh windbreak? I just got the car and can't see anything obvious roof down and can't access anything roof up! I know it will be obvious, but ... Thanks.
The hooks, 3 on each side, slide up under the trim pieces. The ones on the end are easy to attach but the the others are a little more difficult. You need to get the top to a half open position and then slide them in.
I found it bit of a fiddle but disconect the two velcro hooks and with roof full up, insert the two hooks from by the flat bit, at back of the roll bars then i put the roof full down holding on to velcro bits. Then put the windbreak on, put roof back up and after more fiddling conected all the hooks. can be a bit of headache :headbang: hope this helps but when youve do it once its easy. :driving:
