ODB2 Fault Code? **Updated**
Swiftly
Elite
 Edinburgh
Tonight my check engine light came on (yellow) after only 2 minutes of driving, hadn't got out of 2nd gear or above 20MPH. I plugged my code reader in when I got home and the code is P1154 undefined code? Does anyone have any ideas what it actually means or where I might find any info?
The temp at the time the light came on was zero degrees outside and snowing, however the car appeared to run fine, no adverse symptons noticed. I have cleared the code and the lights gone, so will see if it comes back. Just wondering if the code was down to the bad weather or dampness.... possible 02 sensor heating issue may be as the code is in these error code ranges, just guessing so its a stab in the dark.
imo just drive it if it feels fine, i had the light going on and off for a couple of months till i found a perished hose
As a guess it may be a dirty o2 sensor, they get a carbon build up, or the pre heat has failed, which is why the light came on when it was cold, then again it may be something else
Just an update to say that I managed to get the zed into the dealers this morning to finally diagnose my check engine light which has been coming on and off a number of times recently. It looks like it could be either dirty/sticky vanos solenoids or a solenoids on the way out. I have to say that despite the check engine light coming on, there was no other symptoms noted, no hesitation or rough idle. Got it booked back in a weeks time for them to hopefully sort it out.
