Occupancy Mat Bypass - Which one?
andrewr
 Brentwood, Essex
Hi all,
Having searched through older posts, it seems all of the ebay links are dead.
I'm wanting to fit a facelift seat into a pre-facelift, does anyone have any recommendations for which occupancy bypass to go for?
Many thanks
Andrew.
http://www.ebay.co.uk/itm/BMW-Occupancy-Mat-Bypass-Passenger-Seat-Airbag-Sensor-E36E46E38E39E61E65M3M5X5Z4-/150987299594?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item23278b5b0a
Z4M-2006 said:
I have a brand new unused one in my toolbox.
£10 posted if ya want it..
Super, does this work for facelift seats into a pre-facelift? If so, I'll take it!
Andrew.
Thanks, I was looking at this one, but the seller tells me they're for pre-06 cars, however the seats come from a facelift so I was unsure whether this was correct. Do you have experience with this part?
Andrew.
Not sure mate...But thinking about it....
I'm sure it connects to the cars wiring loom not the seat itself!
The adaptor will work as it plugs into the cars wiring loom not the seats, thus plugging this in to your preface lift wiring loom disables the seat pad function on your car regardless if you have a seat fitted or not... :)
Andrew.
Hi bud..
Im not 100% sure......
But if you give me your address i will send it down to you,if it works you can send me the £10... If is doesnt,then send it me back...
Andrew.
Hi bud..
This is what makes this forum great :)
:thumbsup: I agree, this is definitely the best forum on the net!
Super! Thanks for the offer, I'll give you a shout once the seats arrive (in 2-3 weeks) and I'll give it a try!
Andrew.
Andrew.
No bother....Its not going anywhere soon..
Devilsadvocate said:
Remember to buy a seat belt clip to override the beeper telling you to fasten the passenger seat belt
... :thumbsup:
I've heard mixed stories about this. Some people om here don't seem to need this. Do you use an occupany bypass and blet clip?
Anyone else have experience?
Andrew.
If fitting facelift seats you need to do the following:
Fit occupancy black box from pre-facelift seats to new facelift seats, them fit bypass module.
Second is either by a seatbelt clip as the car thinks there is always someone in the passenger seat, or get the car coded via SSSv32 retro section and disable seatbelt chime to passenger seat.
I am working on a failsafe system to completely over ride the airbag light problem as part of my build. I literally connected everything up today without the bucket seats going in to see if it all works out ok and it all fits fine! Remembr the airbag light WILL go on unless you disconnect the battery beforehand for at least 20-30minutes also its worth nothing the airbag light is also activated from improoper installation of the seatbelt pre tensioner wires too.
When the dust has settled on project marmite I may do a compelte write up of how to instal after market seats into an e85 as there isnt one on the net yet.
:thumbsup:
:thumbsup:
I'll be interested to hear which method you've used. Keep us posted!
Andrew.
Does the black box from the pre-facelift seat need to be wired up to the actual seat? I'm not keen on using a seatbelt clip permanently, so getting the car coded is definitely the way forward. Is this something an indie can do, or is there other ways to code?
Andrew.
Why would you need a seatbelt clip? Just plug the seatbelt into the harness when you dont have a passenger already using it??? lol...
Is this your fail safe method we're all waiting for? :P
Andrew.
Andrew.
I have already fitted facelift M seats in a pre-facelift car, under the passenger seat is a black box which the occupancy mat cable connects into, this needs to be transferred to the facelift seats as they are connected differently. You need to open up the large connector that connects to the car loom under seat and remove existing occupancy cable and fit black box cable. Bypass module just plugs into black box, tie wrap it to seat frame, job done. Fit seat.
Coding requires as stated SSSv32 in retro section, an Indy should be able to do it. I have software and did it myself. Disable seatbelt chimes to passenger seat.
This makes sense now, it sounds reasonably straight forward. Thanks for the info.
Andrew.
