Hi all,
I'm currently at a complete loss with my 2.2 E85 (M54), and was hoping someone may have a suggestion...
Since owning it (last couple of years), the car has always drank oil, however in the last 12 months this has increased a lot - it's now drinking roughly 3-4L per month (daily driven ~20 miles per day). Around 10 months ago I changed all the spark plugs & coil packs as cylinder 5 had failed, causing a misfire. The plug was coated in black oil (that had baked itself on - not wet oil) and was all okay until last week.
Last week, the car started to misfire and threw up P0305 and P0015, so I changed cylinder 5 spark plug (and checked the others) again before my 100 mile journey home. The next morning I checked the plug and it was again coated in baked-on oil, so I cleaned it up and went for a ~15 minute drive - the whole drive, the car was misfiring and running rough, had a jumpy idle etc... I then cleaned the plug and travelled back down the road (100 miles) and the car was absolutely fine, no misfiring at all (bar the first 10 minutes that were a little rough). I am unsure as to why only one cylinder gets coated in oil, but the rest are fine..? And the car stops misfiring once the engine has been running for a sustained period of time?
For reference, I changed the rocker cover gasket around 12 months ago to try and limit the oil loss. I also have a fair amount of oil pooling towards the bottom section of the engine however can't find any leak at all. The coolant light comes on periodically, although the coolant seems to never deplete (this may be a sensor issue, however thought I'd include just in case).
I have read that the CCV/PCV valve could be a good start look at, however wanted to see if anyone had a similar issue first before doing it.
Any help would be greatly appreciated
