I insbroker2 Member Dec 9, 2024 #1 2003 2.5 OBD II port stopped working. Fuses tested and are good. scanner works on other vehicle. Help?
Rockhopper Senior member Mansfield Site Supporter Dec 9, 2024 #2 Do you have a fault you are trying to track down? What code reader is it? Has it ever worked on the Z4? Check for bent pins. Ignition tuned on?
I insbroker2 Member Dec 9, 2024 #3 Fowwell NT710, ignition on, The port was working and just stopped. car has not been started.
Rockhopper Senior member Mansfield Site Supporter Dec 9, 2024 #4 So the car doesn’t start? Try disconnecting the battery for ten minutes. Still no joy then it’s pointing towards an ECU fault perhaps.
I insbroker2 Member Dec 9, 2024 #7 Testing on the other BMW indicates it’s the Foxwell scanner. Hoping they can repair it.
