O/S LIGHT
marypoppins
 Preston
I have just notice that my o/s headlight glass looks dirty. This is inside the unit and must be a result of misting at some point. I have seen articles on the forum before with reference to drying out, however it is dry. Can i strip the light down and clean the interior of the glass, or is there an alternative way do do this ?
If it's on the inside - you'd need to open up the light unit.... which could mean getting a dremel handy :(
I think you can access the lens if you remove the inners from the rear too, but I'm not sure if you can remove ALL the inners from the back of the unit
