Now I'm going to have more rattles
Big Red Cat
 Wiltshire
The alloys on my lovely new Alpina RS need a refurb & are leaking a bit of air. Today I thought I'd get my so-far unused tyre inflator out to make sure the tyre pressures were correct only to find my cigarette charger wasn't working :x So into the glove box & fuse box, once I'd worked out exactly which bits I was supposed to be pressing & pulling :? Found the spare fuses & tweezers to pull dud one out. It's #5 the very first, bottom row on the left. Got the tweezers on the fuse gave it a tug, tweezers shot out & dropped down a hole into the depths of the underside of the glove box. Borrowed another set of tweezers from my sister's car & making sure I kept a very tight hold on them pulled the dud fuse. This time both shot out I kept hold of the tweezers but the fuse dropped down the hole too. Now I bet both objects will rattle around annoyingly :headbang:
Is there an easy way to drop the whole glove box out or does it involve removing lots of trim?
Glovebox is easy to remove, half a dozen screws from memory. A couple each side and two or three along the bottom.
