randyf said:
OK I am going to lube the joints and lube the worm driven gear via drilling small hole. thx
That should work.
What I find interesting is the way this happened before I greased the steering column. I would park the car facing the sun on a hot day with the top up. The car was parked in a large shopping parking lot. Driving around the parking lot while the steering and the servo was hot I never had any sticky or notchy steering while at low speeds. The servo assist never cuts out from the heat during low speed driving. In my case the worm and ring gear in the column stuck because of too tight of tolerance while hot and lack of lubrication. This sticking happens at higher speeds when the power assist is reduced automatically by the steering ECU. It was even worse with the sport mode on which reduces steering assist even more. So while the steering is programmed to reduce assist at high speeds the worm and ring stuck together causing the feeling of notchiness. Not that the servo overheats and cuts out. BMW did not change the servo drive in the column on the facelift model. They changed the tolerances between the worm and ring gear, made the worm gear smoother, and changed the type of grease used for this assembly.
