notchy shift in z4m coupe
mad4slalom
hi, anyone fitted a different clutch stop, and does it help the gearshifting at all or adjusted the stock bmw one, 2007 z4 m coupe, thanks, any thoughts.
Is the gear notchy or are you talking about the release of the clutch?
I have a clutch stop but i didn't get it to improve the shifting action, just to reduce the "dead space" behind the clutch. Helps for heavy stop/start traffic and makes very quick shifting a bit faster.
Remove clutch delay valve (CDV) should help.
Quick search on YouTube will show you how. Googling will explain why... :thumbsup:
It's normal that the gear is notchy... Had the same question when I got the car; http://www.z4-forum.com/forum/viewtopic.php?f=9&t=23956&hilit=gearbox
Don't believe the CDV delete does anything to reduce notchiness as it only slows the flow of fluid when you're releasing the clutch pedal!
Yeah ok :oops:
I'll butt out, I've not got an ///M, but do support CDV removal. I think it's pointless
Adamski said:
Yeah ok :oops:
You support it, but you think it pointless...
You dont work for a political party by any chance? :lol:
I read about the clutch stop mod and was sceptical about it. I made my own so that there's minimal dead space under the clutch pedal and I've been very surprised at how effective this is in overcoming the clutch delay valve problem. When the clutch stop is fitted, you just press the clutch pedal until it hits the stop, change gear, and release the clutch without any left foot modulation and you're off again. It's very worthwhile.
I used a 40mm M10 bolt with 3 nuts, one of which I use as a locking nut when the stop is properly adjusted, and fitted a rubber chair leg stop over the bolt (had to buy four of them from Homebase - that's where all the cost went!) and two other nuts. It cost me about £4 in all.
Is there not an adjustment on the linkage to the clutch master cylinder? We used to do it on the Evo's loads to give the bite near the top of the throw.
The point of the clutch stop mod isn't to raise the height at which the clutch engages but to determine the actual engagement point just after you lift off from the stop beneath the pedal. This way you're not having to modulate the clutch with your left foot to get engagement to avoid the kangarooing and possible problems caused by the CDV (clutch delay valve).
I have a BMW weighted shift knob in my Z3MC which does help. I wouldn't want a metal knob like those Stormwerks ones: they're either too hot or too cold to touch. I'm going to lift the gaiter on my Z4MC and see if it's possible to wrap some lead around the shifter, out of sight.
