Q 2. Can you fit normal tyres to a car set up for Run Flat tyres?
No, you should not put non-Run Flat tyres on a car set up for Run Flat tyres! There are two main reasons for this.
Because Run Flat tyres are very hard due to the reinforced sidewall, the suspension on the car is set much softer so the ride is normal for occupants. If a normal tyre is fitted then the ride will feel very soft, the handling will be adversely affected and could present serious safety concerns.
As the car will not have a spare or anyway to deal with a flat tyre, if non-Run Flat tyres are fitted, the car will be stranded if a puncture does occur.
*Copied from site*
*Copied from site*
I wonder if the newer BMW's have suspension compensated for in this respect?
