no sound out of speakers?? please help
staplesz4
 new jersey
ok i attempted to put in a aftermarket head unit in my car but afte i got the oem out and put the aftermarket in... the headunit lit up and everything worked buttt noo sound out of thespeakers any ideas and y?
not enough info matey, u dont have a DSP system do you? Check the pin outs at the HU end..
put it this way cause i hooked up every wire and everything worked besides the sound.. i have the preimun sound package in my car no navi and no ipod dock or aux
Have you tried plugging in the old unit to see if this still works? Would narrow down where the problem is.
You could plug just two wires in ( + & - ) and everything would look like it worked with no sound, so that doesn't really help.
If you have the DSP amps then it could be a lot more complicated than you think.. Do you have the subs behind the seats? This system is all driven optically and it's nothing like as simple as just putting another head unit in.
Have a look in the FAQ at the audio section - there's loads to help you there.
