Just bought a Z4 project car please refer here to background: http://www.z4-forum.com/forum/viewtopic.php?f=11&t=70948
There is no sound coming from the radio , CD changer, Sat Nav or anything the Sat Nav operates fine and the radio tunes too but there is no sound output. Also there multi changer magazine is stuck and does not eject.
I have checked and found that the fuse for the multi changer is missing no.48 I think, and also that the where the amp is supposed to be next to the battery there is nothing there, I'm not sure if the amp is required for sound function or if it was supplied with the car and removed or simply not supplied/required. I'm sure someone with know this. In regards to the fuse I can only assume that someone has tried and failed to diagnose the fault in the past and perhaps taken the amp out as a result and the fuse out because it was short circuiting something else or causing other issues e.g a flat bat?
Or could it just be a simple case of replacing the fuse and everything works? Surely not gonna be that easy?
I welcome all of your help to get this working, thanks everyone!
