Not that I use it, maybe that is the issue, but just before laying up for the winter I was using to demist and noticed it had stopped working, and now of course still is
On a route to fault finding, these are symptoms
Air con light comes on when pressed
Blower ramps to fast and blows hot when set accordingly
Rear window heater OK ( so not transport mode )
Fuses all good
ECU scan - no errs or pending
Comp clutch is not engaging when pressed ( no noise or rev drop )
A few more checks I can do from searching, but some questions first you might be able to help with and best next step
Again, I can well live without A/C but its just something that is broken and that bugs
Fuses all good
- The coolant would have to be near on empty to not work at all ? ie needs a very low pressure. Can I check that by pressing the release valve just to see if any hiss, is there a visual anywhere on correct pressure
- Should I see a fan come on instantly when switched on ?
- The corroded green wire to the fan some have mentioned - is that the best next step to check ?
- Where is the compressor, which end host the magnetic clutch - is spraying it with WD safe, clutches don't like lube ?
- Can I prove the comp is OK by loading the connectors directly ? is that safe
