New wheels it is then, now which ones???
I have mv3 style wheels on 335i and that car has given me sleeplers nights. Worst car I've ever owned.
For that reason I vote csl's :)
Ducklakeview said:
mr wilks said:
You go with what you like mate but RE the widths you would barely notice any difference but would be far better with comfort & visually with slightly more on the wall
Se cars on 18s with 35 profile rears can look hellish gappy around the arches imo
Can't see that much difference TBH, more worried about an under reading speedo as I tend to set cruise to 85mph on the motorway, which equates to just under 84mph via GPS, crucially 1mph under the ACPO guidelines for a prosecution :D
Handy tyre size calculator and visualiser site; https://tiresize.com/tyre-size-calculator/
And this site shows the difference in offsets, which could be handy.. http://www.willtheyfit.com/index.ph...idth2=8.5&offset2=34&Submit=Calculate#content
Mike
You can throw numbers into as many online calc sites as you like but from past experience a 18inch 8.5 rim with a 255 35 profile tyre will always look gappy on a se car & even on a Sport can easily stand to raise the numbers to what the ZMs run of 255 40 & 225 45
As for the speedo , ive changed wheels & tyres on countless cars of all makes & only when fitted & driven against a GPS satnav will you get a true accurate reading as all manufacturers set their speedos at varying tolerances
My current Z has gone from OEM 18s to 19s yet ive kept the profiles the same so 255 35 19rear/ 235 40 fronts for increased comfort & reduced arch gap , the speedo is now more accurate than it was on OEM set up :wink:
If you fit what you like you can't have any complaints
This is a Se roady i had a while back on 18s with 45 fronts & 40 rears / 265 40 18 on 9.5j & 235 40 18 on 8.5j et 35
& same car / same springs with standard 108 on 255 35 rubber
Ok, I have made my mind up (I think)
Gonna give the 108's another chance, as I do like the look of them. Gonna give City Powdercoaters a try in Birmingham, £40 per wheel, same day including removal and refitting from car and tyres taken off, refitted and balanced..
Mike
Mike
That's crazy cheap! Are you not worried about quality? And do you know if they are going to split them?
Thanks Mr. Wilks. This is all I will ever need to know.
You are "The Man" of wheels and tyres ! :ilz4f:
Mike
Yes they will split, and if the quality is not good, they'll be doing them twice. Having seen other posts from people who have used them though, I'm not unduly worried.
Mike
Ducklakeview said:
Mike
Mike
Look forward to seeing the end results. Mine need doing badly but I live quite a long way from Birmingham. Would be worth the travel at that price!
Mike
Same day :o :?
" IF "all 80 bolts play nicely its a 2 hour job for 1 man to split the 4 wheels , followed by a similar time to rebolt the 4
Throw in some tyres off / tyres on + balance & that doesn't leave a lot of time to strip , blast & powdercoat the rims & stars :?
KERMIT1970 said:
£40 a wheel & they'll split them :o good luck with that ! :thumbsup:
It's actually only £20 if you supply just the rims, the £40 is for them being on the car plus same day...
Time will tell, but hoping to get there next weekend..
Mike
Good choice.
No way £40 I'm afraid. Ask what they'll be doing for that.
I paid £600 at Lepsons Inc vat just to give you an idea, and that unfortunately didn't even include new titanium bolts, although I was tempted.
Mike
Still waiting on the 40 quid a wheel 108's refurb :poke:
Here is a link to some pics of the 18 inch VMR 718 CSL reps I installed on my SI recently:
http://www.zpost.com/forums/showthread.php?t=1294464
Velocity Motoring is a US manufacturer. I quite like the new wheels. To be honest, the pictures don't do them justice, much nicer in person.
