New wheels advice needed
firebobby
Elite
 South west Buckinghamshire
Have just bought a set of 108's and want to do a refurb on them, I placed them on the garage floor and splashed some releasing fluid onto the bolts. I will let them sit for a day or 3 and then try and get the bolts out. My question is, what size and type of tool do I need to undo these bolts.
Thanks for the link mr wilks, very informative :thumbsup:
It looks like the bolts can be a pain to get out, I will let them soak for a while and get a good quality 8mm splined tool and give them a go.
Does MM still do the broken bolt removal service ?
I have been looking at spline tools and there are plenty of them on ebay, but not sure of the quality, It looks like the bolts will very tight to get out, so I will need a good quality tool. Halfords do a 7 piece 1/2" set for around £24, it's their Professional range, would these be up to the job. Anyone had experience with these or recommend a spline tool.
I'm sure anyone who has split 108s can offer their own wisdom but after parting 15/20 sets here's my advice
First off i found heat or cold no use & also no benefit from using penetrating fluids or sprays
I use a longer spline (50mm) to "strike" each bolt with a heavy hammer 2/3 times . This helps break the thread if seized as most of them are . Once struck 2/3 times use a separate wrench with fresh spline in almost immediately
I also found removing the bolts in a star like pattern so opposite around the wheel face as opposed to next to each other clockwise
Don't use excessive force or longer wrench as it will either round the head or snap the thread
Leave the ones that don't move & return to them , not unusual to end up with a wheel with 2/3 stuck bolts , repeat the strike / try & if still no movement i would leave overnight then try again .
Worse case if the head does round off is drill the bolt head to leave the thread & once the star is off then you can get at them to remove
I found grinding a flat surface with small grinder to 2 sides of remaining threaded shaft the easiest way to get threaded bolts out , just turn them out with small suitable size spanner
A satisfying job once complete but in reality can be time consuming & laborious
Keep us posted how you get on :thumbsup:
Thanks for the advice mr wilks, I have already given them a good drink of release fluid..it can't hurt I suppose, can I ask where you got your spline tools from. Do you think a cheaper one for the hammer work would OK, then get a good quality tool for the final part.
