The thing you have to remember about tyre pressures is that 1psi is around 20-30lbs/inch of spring rate.
So, lowering the pressure of your tyres will give a more forgiving ride, but going too low without replacing the springs will make the car sloppy and unresponsive when cornering. You'll wear the shoulder of the tyres out too if the pressure is too low
