I recently purchased a 2004 3.0i with a manual transmission and its in pretty decent shape for 107,000 miles
I've been reading up on issues and solutions but I see so many of the posts are old and photos are no longer linked which makes me a bit more apprehensive about getting too deep into working on the car myself. Rather than making a bunch of posts for individual concerns, I'm going to share my current list of worries for anyone to comment their experience on. I appreciate any kind of feedback you might have for me!
The power top has stopped working, after reading around I believe the main motor is partially to blame along with the passenger side seals. There were some great write-ups on how to relocate the motor and replace all the bits without needing to remove the top, so I'm grateful to have found those at least! Any other tips from experienced owners on repairing the top?
I was also able to find some diagrams to help me understand the audio system wiring as my car has a very poorly installed aftermarket amplifier and radio. The subwoofers in the car have been replaced by aftermarket brand speakers, some reading around it seemed like the OEM subwoofers were specific to the stock amplifier. Do I need to have the OEM subwoofers to make an OEM amplifier work? The goal is to get the audio back to 'stock' or as close as possible. I've also read that were I to reinstall an OEM radio unit, it would need to be programmed into the car? I haven't found info on how to do this. Not entirely sure what the OEM load out was, this car has 10 speakers, without navigation. The OEM amp and OEM radio are gone.
I have no experience with BMWs at all prior to this, the engine seems to run strong but I am the 7th reported owner of this vehicle and the only regular service records are dated back to the late 00's. Is it safe to run a fuel system cleaner on these engines? Is it safe to use standard MAF cleaner? I've read that there is an ICV separate from the MAF that also needs to be cleaned occasionally, is there a preferred way to maintain this hardware?
I have also read some info about the DISA system being a potential disaster and tell-tale signs being a rattle at lower RPMs. I believe this car has that rattle, but the EML currently shows no error codes. Is it best to clean the DISA, Replace it, or repair it with a no-fail kit?
I have also noticed a rather unnerving "clattering" sound when shutting off the engine. I read that this has to do with the clutch and if I shut the engine off while I have the clutch pedal depressed, the sound goes away. I did not see where a solution was posted; is this a sign of a bad clutch? I only have the clutch in my ford focus to compare to and it really feels about the same as far as pedal travel and engagement is concerned. How will I know if I need to replace the clutch?
